Author Topic: Hi, I'm Maciek from Poland  (Read 70490 times)
Offline icemac
    • www.miniclassic.pl
Odg: Hi, I'm Maciek from Poland
« Reply #105 on: November 21, 2011, 07:38:47 AM »
i would rebuild the whole engine.
that's the last option ;)
we would like to use this car next two or three years, and then make rebuild and restoration.
but, if the engine will be totaly dead, i have to make rebuild to next march.
« Reply #106 on: November 21, 2011, 20:38:51 PM »
try to find somewhere "ropa naftowa" (google translate) that's good for awakening engines with problems like that
Offline icemac
« Reply #107 on: November 23, 2011, 10:14:38 AM »
i poured paraffin oil it in the engine, and i'm waiting ...
but right now, i think about "new" engine, or total repair this old ...
« Reply #108 on: November 23, 2011, 14:40:16 PM »
if poured paraffin oil does not help.... just put engine apart to see how bad is damege..... after that you will not what to do.
mybie just bore block and change the pistons ..... and change all bearings, seals, clutch, chain, oil pump..... check the head (valve guides, valve seats), check the gearbox (synchros and all tolerace, diff pin,....) and your engine will be ready for next 200.000km!!!
Offline icemac
« Reply #109 on: November 24, 2011, 08:35:49 AM »
engine looks like on this photo ;)
cylinder head:
cylinder head must be repaired - rocker and valve springs are good with no damages, two valves with small rust.
i think it is not so bad  :good:
Offline icemac
« Reply #110 on: December 12, 2011, 11:24:52 AM »
After finding all of needed tools, I disassembled engine
pistons are right in the jar of oil, piston rings are glued with pistons ;)
this week I'm going to repair engine blok, today I'm picking cylinder head after repair  :uraa:
« Reply #111 on: December 20, 2011, 08:13:53 AM »
Hi Maciek!
how is going?
did you find new pistons?
Offline icemac
« Reply #112 on: December 20, 2011, 13:06:18 PM »
Hi Maciek!
how is going?
no ...
i bought "new" engine at a good price  :)
« Reply #113 on: December 20, 2011, 13:07:37 PM »
is it  original 1,1?
or higly tuned 1380 with comressor  :wink:
Offline icemac
« Reply #114 on: December 20, 2011, 17:02:18 PM »
is it  original 1,1?
original 1,1 :P
« Reply #115 on: January 23, 2012, 08:53:55 AM »
pic from icemac
Offline icemac
« Reply #116 on: January 26, 2012, 09:46:11 AM »
nice photos ;)
news
- engine at home :D
- body reapired
« Reply #117 on: January 30, 2012, 21:08:08 PM »
 :bravo: :bravo: :bravo:
Offline icemac
« Reply #118 on: February 03, 2012, 07:32:37 AM »
Cosmic wheels  :good:
Offline icemac
« Reply #119 on: February 13, 2012, 12:49:58 PM »
engine outside
and inside
today new Polyurethan cones, Hi-lo and Cosmic wheels  :good:
