: 1 ... 5 6 [7]
: MINDžONI...  ( 36496 )
Odg: MINDžONI...
« #90 : May 05, 2013, 08:39:20 AM »
mare svaka cast...nisam ni sumnjao :mks:
Odg: MINDžONI...
« #91 : May 21, 2013, 20:10:20 PM »
POTREBNA POMOĆ!!!!!
n both cases the bushes need to be properly orientated to achieve the correct angle of fitment for the offset steel sleeves. The bushes are therefore marked with a fine line on the narrower side of the bush flange (check top and underside of flange). The front bush (nearest front of car) should be fitted with this line pointing down the centerline of the bottom arm towards the wheel. The rear bush should be positioned with it's line 180 degrees the other way, so pointing in towards the centerline of the car. Trial fit the bushes and bottom arm pin to the arm before fitting to the car - the pin should fit easily through. If the bushes are not correctly aligned the pin will not fit easily.
Potrebna pomoć za pravilno postavljanja ovih gumica....prevod mi baš nije jasan na podvučenom delu teksta.....
Gregore,da li je ovo ispravno pozicioniranje offset gumica?
Odg: MINDžONI...
« #92 : May 21, 2013, 21:32:41 PM »
neznam na pamet..... ali pogledat ču sutra po mojim slikama iz arhive i šaljem.
: 1 ... 5 6 [7]
