Author Topic: Žućo Mini 1100 Special  (Read 100991 times)
Offline banex
Odg: Žućo Mini 1100 Special
« Reply #15 on: October 20, 2009, 13:23:41 PM »
lep i fabricki 99%!
cestitam i ziveli  :pivo:
« Reply #16 on: October 20, 2009, 20:31:38 PM »
Dobar primerak :good:
« Reply #17 on: October 21, 2009, 07:43:15 AM »
 :good: :good: :good:
e sad uzivaj
« Reply #18 on: October 21, 2009, 08:25:31 AM »
hvala puno svima
« Reply #19 on: October 22, 2009, 02:02:29 AM »
   pozdrav divac,i uzivaj u voznji i  :stekaj: za :pivo:
sto se tice proizvodnje minija 1100 specijal,po podacima iz autodate,proizvodio se od 1976 do 1980g,i to nepricamza ostale modele ukoje je ubacivan 1100cc motor,jer nisam uspeo da nadjem druge podatke...
« Reply #20 on: October 22, 2009, 09:20:57 AM »
sto se tice proizvodnje minija 1100 specijal,po podacima iz autodate,proizvodio se od 1976 do 1980g...
Prvi puta cujem... :0_0:
Svaki dan naucis nesto novo  :good: ...svaka cast...di si pronasao te podatke?
« Reply #21 on: October 23, 2009, 00:47:32 AM »
evo korisnog linka,stosetice podataka kubikaze,snage i godine proizvodnje motora,kao i izgleda
http://www.aronline.co.uk/index.htm?engineaseriesf.htm
meni jeproblem da sve ovo prevodim,pa pustite prevod za nas ostale...
« Reply #22 on: October 23, 2009, 01:12:44 AM »
]bavezno pogledajte ovaj link,jer ima zanimljivosti od minija prototipa pa i ostalih engleza prototipa,a i nesto sto je i vidjeno u malo izmenjenom ruhu...
« Reply #23 on: October 23, 2009, 08:57:04 AM »
Ja tu vidim da se Specijal proizvodio 79-80... :thinking:
« Reply #24 on: October 23, 2009, 12:51:00 PM »
Specifications & applications
Capacity   Bore   Stroke   Max. Power   Max. Torque    Applications
803cc   58.0mm   76.2mm   28bhp @ 4400rpm   40lb ft @ 2200rpm   1952-56: Austin A30
30bhp @ 4800rpm   40lb ft @ 2400rpm   1952-56: Morris Minor Series II
848cc   62.9mm   68.26mm   33bhp @ 5300rpm   44lb ft @ 2900rpm   1969-80: Mini 850 / Mini City
34bhp @ 5500rpm   44lb ft @ 2900rpm   1959-69: Austin Seven / Austin/Morris Mini
1961-62: Riley Elf / Wolseley Hornet
1964-68: Austin Mini-Moke
948cc   62.9mm   76.2mm   34bhp @ 4750rpm   50lb ft @ 2000rpm   1956-62: Austin A35
1958-61: Austin A40 Farina
37bhp @ 4750rpm   50lb ft @ 2500rpm   1956-62: Morris Minor 1000
37bhp @ 5000rpm   50lb ft @ 2500rpm   1961-62: Austin A40 Farina MkII
43bhp @ 5200rpm   52lb ft @ 3300rpm   1958-61: Austin-Healey Sprite
46bhp @ 5500rpm   53lb ft @ 3000rpm   1961-64: Austin-Healey Sprite MkII
1961-64: MG Midget
970cc   70.6mm   61.91mm   65bhp @ 6500rpm   55lb ft @ 3500rpm   1964-67: Austin/Morris Mini Cooper S
997cc   62.43mm   81.28mm   55bhp @ 6000rpm   54lb ft @ 3600rpm   1961-64: Austin/Morris Mini Cooper
998cc   64.58mm   76.2mm   38bhp @ 5250rpm   52lb ft @ 2700rpm   1962-69: Riley Elf / Wolseley Hornet
1967-80: (Austin/Morris) Mini
1969-75: Mini Clubman
41bhp @ 4850rpm   52lb ft @ 2750rpm   1969-80: Mini Clubman (auto)
55bhp @ 5800rpm   57lb ft @ 3000rpm   1964-69: Austin/Morris Mini Cooper
A+ specification   39bhp @ 4750rpm   52lb ft @ 2000rpm   1980-82: Mini 1000 / City / HL
40bhp @ 5000rpm   50lb ft @ 2500rpm   1982-88: Mini HLE / City E / Mayfair
41bhp @ 5400rpm   51lb ft @ 2700rpm   1980-90: Austin Metro
42bhp @ 5250rpm   58lb ft @ 2600rpm   1988-92: Mini City / Mayfair
44bhp @ 5250rpm   52lb ft @ 3000rpm   1980-82: Austin Allegro
1071cc   70.6mm   68.26mm   70bhp @ 6000rpm   62lb ft @ 4500rpm   1963-64: Austin/Morris Mini Cooper S
1098cc   64.58mm   83.72mm   45bhp @ 5250rpm   55lb ft @ 2900rpm   1975-80: Austin Allegro
45bhp @ 5250rpm   56lb ft @ 2700rpm   1975-80: Mini Clubman
1979-80: Mini 1100 Special
48bhp @ 5100rpm   60lb ft @ 2500rpm   1962-71: Morris 1100 / Morris Minor 1000
1963-74: Austin 1100
49bhp @ 5250rpm   60lb ft @ 2450rpm   1973-75: Austin Allegro
55bhp @ 5500rpm   61lb ft @ 2500rpm   1962-68: MG 1100
1963-67: Vanden Plas Princess 1100
1965-68: Riley Kestrel / Wolseley 1100
56bhp @ 5500rpm   62lb ft @ 3250rpm   1962-64: Austin-Healey Sprite MkII
1962-64: MG Midget
59bhp @ 5750rpm   65lb ft @ 3500rpm   1964-66: Austin-Healey Sprite MkIII
1964-66: MG Midget MkII
1275cc   70.6mm   81.28mm   54bhp @ 5300rpm   65lb ft @ 2550rpm   1974-80: Mini 1275GT
58bhp @ 5250rpm   69lb ft @ 3500rpm   1967:      MG 1275 / Riley 1275
1967:      Wolseley 1275
1967:      Vanden Plas Princess 1275
58bhp @ 5250rpm   69lb ft @ 3000rpm   1967-74: Austin 1300
1967-73: Morris 1300
1967-68: MG 1300 / Wolseley 1300
1967-68: Riley Kestrel 1300
1967-68: Vanden Plas Princess 1300
59bhp @ 5300rpm   65lb ft @ 2550rpm   1969-74: Mini 1275GT
59bhp @ 5300rpm   69lb ft @ 3000rpm   1973-80: Austin Allegro
60bhp @ 5250rpm   69lb ft @ 2500rpm   1968-71: Austin America (auto)
1971-80: Morris Marina
65bhp @ 5750rpm   71lb ft @ 3000rpm   1968:      MG 1300 / Riley Kestrel 1300
1968-73: Wolseley 1300*
1968-74: Vanden Plas Princess 1300*
* Automatic models retained 58bhp unit (see above)
65bhp @ 6000rpm   72lb ft @ 3000rpm   1966-74: MG Midget MkIII
1966-70: Austin-Healey Sprite MkIV
1971:      Austin Sprite
70bhp @ 6000rpm   74lb ft @ 3250rpm   1969-74: Austin 1300GT
1969-71: Morris 1300GT
70bhp @ 6000rpm   77lb ft @ 3000rpm   1968-73: MG 1300 MkII
1968-69: Riley Kestrel 1300 / Riley 1300
76bhp @ 5800rpm   79lb ft @ 3000rpm   1964-71: (Austin/Morris) Mini Cooper S
A+ specification   50bhp @ 5000rpm   66lb ft @ 2600rpm   1992-2000: Mini Sprite / Mayfair
61bhp @ 5550rpm   61lb ft @ 3000rpm   1990-91: Mini Cooper
61bhp @ 5300rpm   69lb ft @ 2950rpm   1980-84: Morris Ital
62bhp @ 5600rpm   72lb ft @ 3200rpm   1980-82: Austin Allegro
63bhp @ 5700rpm   70lb ft @ 3900rpm   1991-1996: Mini Cooper 1.3i / Cabriolet
63bhp @ 5500rpm   70lb ft @ 3000rpm   1997-2000: Mini Cooper 1.3i (TPi)
63bhp @ 5650rpm   72lb ft @ 3100rpm   1980-90: Austin Metro
64bhp @ 5500rpm   73lb ft @ 3500rpm   1983-85: Austin Maestro HLE
68bhp @ 5800rpm   75lb ft @ 3500rpm   1983-93: Austin Maestro
68bhp @ 5600rpm   75lb ft @ 3500rpm   1984-89: Austin Montego
72bhp @ 6000rpm   73lb ft @ 4000rpm   1982-89: MG Metro
73bhp @ 6000rpm   73lb ft @ 4000rpm   1989-90: Metro GTa
77bhp @ 5800rpm   80lb ft @ 3000rpm   1991-2000: Mini Cooper S 1.3i
78bhp @ 6000rpm   78lb ft @ 3250rpm   1990-91: Mini Cooper S
93bhp @ 6130rpm   85lb ft @ 2650rpm   1983-89: MG Metro Turbo
  u pravu si brute jer u autodati ne pokazuje ovu malu razliku u v kubikazi
« Reply #25 on: October 23, 2009, 18:38:29 PM »
A kako je onda ovaj od Divca '77...jedino da je prekrsten... :thinking:
« Reply #26 on: October 23, 2009, 23:30:05 PM »
Pa trebao bi oko 1979.Specijal povodom 30 godina proizvodnje Minija.Negde sam imao tekst sa objasnjenim specificnostima tog jubilarnog modela.Okacicu kada nadjem
Offline mr.Bean
« Reply #27 on: October 23, 2009, 23:55:28 PM »
Mislim da je ipak povodom 20 godina....
« Reply #28 on: October 24, 2009, 01:47:36 AM »
U pravu si,lapsus :good:
Ali takodje postoji specijalna edicija i povodom 30tog rodjendana,imam nesto i o tome
« Reply #29 on: October 24, 2009, 08:56:22 AM »
Pa za svaku desetu godisnjicu je bio LE(limited edition) kao slavljenik...Special je trebao biti za 20tu i zato mi nije jasno kako je ovaj '77 godiste???
